Cheap Double Cardan Drive Shaft?
Rescue Diver
Full Time Jeeper
Kansas City
1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
I just happen to have a front drive shaft laying around from a low miles 2001 XJ Cherokee that's a double cardan, and the U-Joints are the same size as my CJ's and the diameter is similar. I'm thinking of getting it shortened 5 inches and using it in the rear of my CJ.
Has anyone else on here ever used a factory XJ double cardan drive shaft in the back of their CJ, or can anyone give me a good reason why it won't work????
While trying to get rid of an annoying intermittent drive train vibration a couple of years ago, right after I first built my jeep, one of the things I did to try and eliminate it was to lower my cross member with spacers. After figuring out the hard way that my vibration was being caused by a failing nearly new throwout bearing, I never took the spacers back out of the cross member.
A couple of days ago it occurred to me that I was giving up an inch of ground clearance because of them, and I didn't even know if I needed them, so yesterday I bought shorter stainless bollts and washers, and I removed the spacers. Without them, it doesn't vibrate, so it should be ok, but I'm still thinking of installing that double cardan drive shaft just to be sure.
It should work fine. the yoke on the t/c does need to be changed if you have the strap style now.
Fortunately I have the u-bolt type yoke, so I think it'll bolt right up. I already shortened it, welded it back up, and painted it tonight. I'll pick up u-joints and four bolts tomorrow and see how it works. :D
The drive shaft is ready to bolt in. I'll be lifting the rear and starting it in gear to make sure it has no wobble before taking it for a test drive. The weld should be really solid.
