Engine Chevy V8 CJ7, stubby hugger headers or outside frame?
Armyvet25
Beach Runner
Lorain, OH, USA
Which has worked better from those whom have done it, get the larger outside frame rail headers or custom the exhaust with stubby block huggers, the later expecting some custom motor mounting for sure, along with room for the front drive shaft. I will probably have the engine offset if needed 1-1-1/2 towards passenger side, no mechanical fan so I'll squeeze it as forward as possible and finally it will have a slight body lift 1-2" and suspension lift of approx 2". True Dual exhaust not necessary.
p.s. pics greatly appreciated.
The block hugger headers is the better option if you don’t want dual exhaust, but long tube headers perform better. You want to locate your V8 as far back as possible, ideally.
Block huggers are a good choice, keeps the pipes tucked into the frame. Most are center dump which give a good area for routing.
Mine are currently BHs with 2.5" duels and dump in front of the rear axle (not ideal). Got the pipes from a friend afew years ago when I was doing the SBC install, and haven't got around to extending them all the way.
Not a big fan of fender well headers unless your building a gasser.
Thanks for the insight and pictures, looks like hugger headers it is
Are you ok with that ugly and obtrusive crossover pipe under your Transmission
Other than the second muffler, not much cost difference with dual out the back vs a cross-over under the tranny a single pipe out the back. I would hate to have to pull my exhaust whenever the tranny needed work.
Are you ok with that ugly and obtrusive crossover pipe under your transmission…
might not have to, looking at previous post, lift might alleviate that(duels), or I've seen a forward running u turn pipe under the oil pan narrow section on some.
single/duels will decide I guess as build dictates when I get to that point
No way to get around that. Good luck.
There’s always a way…
…to cook oil.
Looks like something to bend up and scrape on any real rocky types of trails. Just stay on the porch hound dog. :)
um....beach buggy and light trails only for this one, header wrap for the pipe...damn nay sayers lol
I always thought the outside frame headers and glass paks looked cool, but I can imagine loud. Since I'm doing a frame off, should be able to run mine front to back duels without too much trouble
