CJ 258 runs good then immediately dies...
- Solutions
- 1
- Springfield, Missouri-U.S.A. Earth
- '85 CJ-7, 258/4.2L 6cyl. Bought new in 1985. Full cage, Warn 8274 winch, Ford 9" rear, front/rear Detroit Lockers w/4:88 R&P. T-5 tranny and 4:1 t'case. 33X12.50-15 BFG/AT, MSD ign, on board air---
Is the ignition control module part of the emissions system? I only ask because I have a 1980 CJ7 Renegade and my ICM was (and remains) MIA when I took the title, as well as the smog pump, the carter carb and I forget what else came from the factory and is now probably in some land fill.
-Jon
"START" and "RUN" are two separate circuits.
See post #9..
Jeep wont stay running.
Not sure you can run without the ICM unless your using a points type dizzy.
