Cj7 cv drive shaft
Cj7 cv drive shaft
doublec
Phoenix, AZ
-1977 CJ7 - 258 - 4.0 HEAD CONV (IN PROGRESS)
-AMC 20 / TRAC LOC - SINGLE PIECE AXLES
-DANA 30 - OPEN
-5" SOA WITH 33 X 12.50 BFG
-ON BOARD AIR
77 CJ7 Dana 20 Transfer Case and AMC20 - Yukon axles
This is my camping vehicle and will only see class 2-3 runs, nothing major. I plan a buggy for the real stuff. And yes, for go the Dana 44 / D60 upgrades.
After completing the SOA lift (approx 4") I planned to go with a CV drive shaft. I do a lot of research before starting any new project and have spent a few hours regarding this subject. I see many have used the Bronco, 80's Chevy and Ranger, and don't forget the XJ / TJ front. I will cut and weld what I need to, local driveline shop for balancing.
I have to replace the pinion seal and truss the AMC 20. Since I will pull the yoke I though I would research a larger u-joint that will fit the 20. The Bronco uses a 1330 or 1350 vs the 1310.
Didn't see anything in my research. Thought I would ask if anyone has knowledge where I can purchase larger yokes out there. This will direct me which way I spend my time researching.
I'm not sure what might be out there as the 20 has a 28 spline pinion which is kinda odball. The ford 8.8 and 9" are the only other 28 spline pinions I know of.
You might try complete offroad or drivetrain america they both sell yokes.
I'd check my angles before I went with a bigger joint as a 1310 can work on a steeper angle than they can.
I agree with you, I'm a DIY type person. Try to do it myself first. Eventually I will swap out the rearend which will need another drive shaft. Trying to save on cost. Thx for your response.
Old Dog, Since I couldn't find the large yoke on the major suppliers I figured they were not available. Just wanted to make sure. Guess I'll go with the stock size. Thanks for the link
$45.00
  22.5%
