CJ7 Dana 44
CJ7 Dana 44
It depends what year AMC you have. My rear brakes on my 76 are 11". I put on a dual diaphragm booster / vette MC setup and can lock all 4 with 33's easy. I can't imagine not being able to do the same with 36's.
Wooly
WW-Do you know what size brakes were used on the '86 CJ7 44's?
WOW:eek: Didn't think a rear '44' ever had brakes that small.
It looked like you could use the same drum on both. But it was the end of a run and I think they were just getting rid of everthing before the change over to the Wrangler.
With the really big tires I imagine slamming on the brakes in an emergency stop and your CJ turning into a tumbling ball going down the road. But keep in mind, I'm 57. I've skidded down the road more than once, so I simply can't ignore my little safety demon.
Lmao I don't think my brakes work that great but Incase they do.. I'm going to try and stay with a lower center of gravity so hopefully it won't be too bad. Currently the jeep has about 6.25" of lift but I'm going to go back down to around 4-5ish after I decide on fenders.
Doesn't that 44 have larger brakes than the 20 did? :confused:
I will compare the brake sizes when I have the axles side by side next week. So far I haven't had any issues stopping with the 36's. It seems my issues are just getting it to move.
If stopping is an issue then I will be adding disk brakes. I have looked at the conversion kits and it's definitely an option that I'm considering.
The one I had was the same size as the Amc20
That's not what I wanted to hear!! I will definitely compare them next week. Worst case we will either upgrade the booster and/or switch to disk brakes.
My families safety along with others on the road is nothing to take lightly.
Taken-Do you have disc on the front and power brakes now?
You will like the 4:88-I run 33's w/4:88's and don't even use first gear on the street.
No issue on the freeway either.
what are your RPMs at 55mph? or do you cruz at a higher speed if so what is the rpm range?
Run'n about 2700-2800 rpm or so(know the OEM tack is off some)at 65mph in 5th.
Yes disks and power brakes. I'm considering doing the TSM disk brake conversion on the rear. I cleaned up the rust inside the drums on the Dana 44 . Hopefully they will be enough for now.
I think y'all will get a kick out of the D44's prior owners sorry excuse for welding. I'll be starting a build thread after this weekend.
TCase Dana 20
