CJ7 transmission swap
The T-4 is among the worst transmissions to go into a CJ. The only 5 speed to go into a CJ was the T-5 . It's just as bad as the T-4 but as a 5th gear. It would be the easiest swap but I wouldn't do it.
When I was in your shoes I put in a Ford T-18 Transmission but that's a 4 speed (a very heavy duty 4 speed). It bolted right up to the bellhousing after drilling 4 holes. I adapted the T-18 to mate to my Dana 300 (I had a '82 CJ7 at the time)
Are you sure you also need a new TCase? If so you could get a tranny and TCase as a matched set. Just make sure the TCase output is on the passenger side.
the NV4500 is a very heavy duty 5 speed. Check out this link: The NV4500 Transmission - Novak Conversions
Ditto with what BusaDave said. How did the 300 Transfer Case give out? Short of running it without gear oil in it, they're hard to kill.
thanks. the front and rear seal gave out when i was on the highway and left a trail of fluid and it burned up.
While not a direct bolt up a AX-15 can be easily swapped in. is a medium duty Transmission , and is a 5 speed..
