Coolant leak from rear differential?!
Jslampe
Des Moines
'83 CJ7 258 5pd D300
Brake fluid leak?
Check the lines above your diff.
And that actually kinda does look like diff fluid. Doesn't look that green to me. Maybe the way the light is hitting it or the flash of your camera?
From the looks of that lower rear cover, it looks like a failed seal on that diff cover.
It's gotten water in it. Time for a clean out and new oil and check the breather that it's up high and working right.
Do you use distilled water and antifreeze, or did you go with the already mixed 50/50 jug?
It's definitely green.
Brake fluid leak?
Not likely. It begins to leak when I idle it.
Yeah, something is failing for sure. What should I be looking for on the cover to indicate failure? Pictures? Anyone have a part number for this piece?
Going to change the fluid this weekend and report back.
Stop driving it-
Bet you have it filled with water........
Check the axle breather line.
Stop driving it-
Will do. What exactly am I checking for? That it's up and out of the way? Anything else I should do?
Question: how would it have filled up with water? I haven't driven it through deep water.
Bad wheel seals, vent tube, condensation, leaky pinion seal, lots of ways to get water in there.
Ck the front axle, along with tranny and t'case also.
What's the history of the jeep you have?
Stop driving it-
I'm glad he listens to you I said the same thing and got no response.
I talk mo-better........:laugh:
Sometimes, it takes more than one to say it........:chug:
I'm going to guess there's no water in there, just a leak at the cover (gasket). The T19 I picked up years ago for my swap had a very "greenish" tint to the gear oil I drained out of it, and I'm relatively certain if there was any water it would have separated since the Transmission sat under the workbench of the guy I bought it from for years.
The smell of the fluid should be a quick tell.
OLG
$35.00
  17.5%
