Misc Custom 2.5" exhaust
Manic Mechanic
Full Time Jeeper
Gold Supporter
Featured
Thurmont MD
85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
No I didn't purge it while welding. It's not a med gas line so wasn't worth the extra cost and time.
In the pic what looks like a hose is actually just my clear shield hanging off my gas bottle regulator
In hindsight I should have gone smaller like 2" to make fitment a lil easier but it all worked out. Had to build from manifolds back. No one makes the Y pipe anymore
Nice work!
I'm at it again this time building a new custom exhaust in 2.5 stainless but for my Jeep that's long overdue.
Pics coming soon
That SS should last a few lifetimes.
Great work, MM. I would use flanged couplings. They are your friends if you need to replace the rear main seal on your engine or that short life thrust bearing on your clutch.
Which one? The AMC 304 is accessible and has joints for dissembly
Mine is an inline 6 with a header
I mean those slip joints are very forgiving during initial install but very difficult to separate when it comes time to drop the Transmission .
I couldn’t get away with the single exhaust pipe on my rig. It’s a tiny CJ5 without a lift and Transfer Case clocked horizontal so I had to tuck in the pipes parallel with the frame rails and no room for a wye. Texas forces me to have cat converter to keep it street legal so my only option was dual exhaust and a cat and muffler for each pipe. I like the note of a single pipe better than dual. A tight overall fit but it but it works just fine.
5s are a little more difficult it can still be done but really you'd have to do like a 1.75" 2 at max and really pay attention to the routing. If paying someone to build it it wouldn't be cost effective. If you can do it yourself you could do it for about 500 bucks cheaper if you don't use stainless.
I'll post some pics of mine in a bit.
This guy with a late model Chevrolet truck had an amazing exhaust note coming out his tail pipe. I mean great great note with no drone yet throaty and not loud. Asked him what he had. A muffler delete! Go figure.
Had to have something other than a straight pipe
