Dana 300/Novak Kit
Dana 300/Novak Kit
Jtoms
Pittsburgh
Not from a Dana 300 , from a D18.
Not part of intermediate shaft kit.
Misplaced part.
I would tend to agree with Gargoyle, not sure it fits a T-18 but there wasn't one like you pictured in my Dana 300 . It looks similar to the thrust washers on the ends of the center idler shaft though, I can see where it could confuse someone .
Quick second thought. You say theres 2 of them, so I'm wondering if they are Novaks version of the thrust washer. Are they about 1/16" thick and do the 2 tangs kinda bend inwards? Did the kit include 2 thrust washers like the ones you took out?
The keyed washer comes with all 18, 20 and 300 Transfer Case rebuild kits (small parts). The keyed washer goes between the case and the output shaft on the 18 t-case. You do not need this part for your 300 rebuild
Part # A990,
Output Shaft - High Gear - Washer - Snap Ring
The odd sized intermediate roller spacer from the intermediate shaft goes in the middle, with a row of rollers on each side;the thinner ones go on the ouside of the rollers, up against the thrust washers.
TCase Dana 20
$45.00
  22.5%
