dana44 vs amc20
dana44 vs amc20
railroadpaul
renton wa
1984 CJ7 eng-258 IL-6, t-5 trans, D300 T case, D30 front, D20 rear
Hello I am new to this forum and I bought my first Jeep a couple of months ago. The question I have, it has a AMC model 20 I am contemplating on changing it out for a Dana 44 . My jeep is a 1984 CJ7 , with wide track 30 front and 20 rear. What do I look for in a Dana 44 , what years of jeep has the Dana 44 , and what will fit my jeep?
There is a learning curve as this is my first Jeep, I'm not new to four wheeling just jeeps
Thanks Paul.....
The only direct bolt in would be a 44 out of a 86 cj.(good luck finding one) Any thing else will be wider than what you have now and will need the perches moved at a min. and narrowing if you want to stay the same width.
You can make a AMC20 as strong as a 44 with 1 pc axles and welding the tubes.
but can you install or do they make a air locker for the AMC20 , and if so will it hold up?
:wtf: There is a lot of hype surrounding the Dana 44 . It is a great axle very popular as well you can find lots of axle shafts, gears and lockers for it. You will spend a lot of money trying to swap in a Dana 44 so be aware of that. I agree with mtnwhlr just by welding/trussing the AMC20 and 1 piece axles you will have an axle that is as strong as a Dana 44 with a larger ring gear :chug: if you want to go to a 44 I found a site out of Cali that will sell you an already shortened Dana 44 rear and front with or without alloy axles AXLES – RP4WD When I called him he had a wide track high pinion 44 on the shelf with axles
but can you install or do they make a air locker for the amc 20, and if so will it hold up?
I just looked for some through a Google search. They are available but :eek:!!!!!
I think I will save that $1k for more :beer:!
Also I agree with making the 20 work with one piece kits and some "extra" welding. (Might get mine welded up soon if I can talk one of my many friends with welding rigs over with promises of cold beer and a steak!)
Another word of advice, don't let more than one welder over at a time; they are all the best that ever was at their trade:rolleyes:. I know, my Dad was a welder.
I think your right, I am just going to build up my Dana 20 , I found an ARB air locker for it, and with trussing, it should be a good working axle. thanks to all for the help....
"never underestimate the power of stupid"
I think your right, I am just going to build up my dana 20, I found an ARB air locker for it, and with trussing, it should be a good working axle. thanks to all for the help....
dont forget the one peice axle shafts.. with a locker the tire will quickly pass the jeep while wheeling.
Thats kinda funny in a way, I am looking at all the options.
