did the team rush
did the team rush
dalefan88
Crazy Sr. Respected Jeeper
ada,oh
what a difference. it starts easier, runs smoother. i love it. now next on the list the stealth gm module.
And how extensive did you go? That can mean different things to different people...
I changed to an aftermarket dist and other parts years ago...
How about a detailed parts list so some of the newbie Jeep owners can get an idea of what you are talking about... :)
i did it a littler cheaper than most people do it. i kept my stock coil for now. but when i get the msd blaster 2 i wont have to change my coil wire, just the pos and neg going to the coil no biggy. now the parts list. i work at advance auto so everything came from there. everything i got was from a 79 ford f150 300cid. i didnt uses the brass terminal cap and rotor. i never had luck with them. i always got bad carbon build up on my chevys with them. so all parts are stock.
rotor# d219z
cap#c193z
cap adaptor # c193a
wires#96171
alot of people do the e-coil. i didnt have enough $$$$ or time to build a bracket to mount it. if you go with the blaster 2 coil you can use your stock bracket.
I use a blaster 2 coil on my CJ. A great coil!
Good information and thanks for sharing...
no problem. heres a pic with napa#s. you can use this numbers and go to any parts store and they can cross them.
here is a pic of the ecoil bracket if you want to make one and go with that coil.
When I did my rebuild I scrapped everything BUT the stock dist. and plugged in a full Jacobas ignition system with Clifford 6=8 upgrades and a Webber carb. It was like I put a friggin V8 in it. My plugs are gapped at .052
when i have the money, i want to get a webber carb.
I used the mount from a spare E-coil I picked up at a J/Y to mount my blaster coil.
I have the AMC 304 in my 7. I did the same using the 84 f350 w/460 parts. Used e-coil and found an msd6a for $40. WOW. Starts fast and actually feels like a v8. Also smoothed out the idle. Gapped plugs to .050
my wife is so sweet. she bought me the blaster2 coil. bad thing was i had to do the dishes to get it.:eek:
I've got the Mopar FI on mine, big difference:D
Depends on what they had for dinner!:D
good thing we have a dishwasher.lol
well i got the blaster 2 on yesterday before the snowstorm.:mad: the only problem i had was i put the coil wire on and it kept popping off. the is a screw in the coil tower. i loosen it up a little and the wire stayed on. how far can you loosen that screw? i dont want to take it out to far and not have the coil work.
Are you talking about the screw that holds the terminal in? The one that is accessible by looking directly down from the top (in the center)?
The one inside the tower where the red arrow is pointing.
attachment.php
I did the msd blaster 2 high vibration coil, it cost 8 bucks more, but i figure it's worth it. I also got metal braided 8mm wire and some ngk Iridium IX plugs, runs like a beast now, just need the ignition box and distributor, then i'll be set.
attachment.php
yep thats the one im talkin about.
I'll have to look at mine but I wouldn't loosen that screw. I believe it holds the terminal to the secondary winding of the coil...
  100.0%
