did the team rush
dalefan88
Crazy Sr. Respected Jeeper
i have a msd thing you put in the coil tower and a coil wire to match it at work. i think i might go and get that. then i know the coil wire will stay on.
Working at a parts store has it advantages...well the msd adaptor didnt work. im taking it back to work tomarrow and getting a blaster3. i have a coil wire for that one.
Working at a parts store has it advantages...- Sometimes a disadvantage too (money)!
I picked up all the NAPA parts, but got the 6 cyl plug wires instead of the 8cyl, the whole setup was about $125.
Well worth it. Funny side note the 6 cyl plug wire set comes with an extra plug wire, 8 instead of 7 wires.
Parts for a 1982 Ford F-AMC 150 Pick Up Truck With A 300 CID I-6 Engine.
Rotor-FA159
Cap-FA136
Cap adapter-FA139
Ignition coil-IC24
I used the napa plug wires for the 6cyl, they are nice and fit the coil.
The site I followed to do the mod:
TFI ignition upgrade - Jeepz.com
Yeah I know I just like making that joke, cause someone always gets the wires and is like WTH. BTW I have the e-coil.The extra wire most of the time is a coil wire. Most kits come with 2 coil wires because the fords had 2 style coils with different plugs on each coil. They had a canister(not desirable) and the e-coil(sqare,desirable).
I think you are going to have a problem with that coil and cap combo. I have an easy fix for the problem, a resistive coil charge. You need to hold a screwdriver in the coil wire and touch your other hand to a ground. Have Mrs.DF crank it a few times.Once again, neighborhood kids are also good for holding the screwdriver. Gotta love the neighborhood kids.
