DIY Dana 20 Twin Stick
Cali74CJ5
Riverside, CA
1974 CJ5 304 T18 Dana 20 Dana 30 and Dana 44 Destroyed Tub Rolled and Rusted, 1978 CJ5 no engine, T150, Dana 20 Dana 30 and AMC 20 Perfect Tub
Greetings Everyone,
Long time viewer first time poster. I have tried to find a write up on building my own twin stick but can only find write-ups for Dana 300s. I have 2 jeeps one is a rebuild project and the other a donor/parts jeep. Both jeeps have a Dana 20 Transfer Case . I was thinking about building a twin stick set up to install and drive it as is while I tear down and rebuild the other t-case when time/cash permits. Once I have the other t-case rebuilt with true axle independence I would just swap the t-cases out and switch the shifter over.
So lets see the homemade D20 Shifters. I need some ideas and what worked and didn't work for you guys. I would rather build my own than buy one from vendors. I have access to scrap metal through work and capabilities for metal working. I would just like to see some of the home-made shifters before I re-invent the wheel.
Thanks!
TCase Dana 20
