Don't do or do this or expensive mistake...
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
From another thread: I mentioned that I popped an inside out hole in my rear differential housing. WHAT!!!! Needless to say I was NOT happy!
After a few set backs, I popped the cover to see what happened. First I thought I might have blown my ring gear .... Nope, the good news is that the gears were/are in perfect condition. Next I feared that somehow the E-locker had come apart. Good news, nope the E-locker is a bit scared but still in good shape. So what happened? Almost ALL the ring gear bolts were loose, a couple were missing and one was broken off. Obviously my fault. I swear that the bolts were torqued down. More than once, with a quick check before buttoning up the cover. How to fix the problem? Clean the threads of all oil, use RED lock tight and torque the bolts properly. (Now I'm worried about the front ring gear bolts. Golly, I hate Transmission oil, it's icky an smells bad. )
The old axle housing was in far from good condition when I started the rear end project. The axles were bent and replaced, the passenger side seal surface was scared up. The OP did a crappy job on some spring over perches, the original perches were warn and some what crushed. To top it all off the "U" bolts had warn almost a complete ring around the axle tubes. Why they didn't snap I don't know. Most of the above problems were ground smooth, welded up, repaired, made whole again. But, I admit to be worried about all that heat making the axle tubes brittle and the possibility of the tubes being warped. Then there is the BRAND NEW hole in the housing.
So, off to Willys Works I went. Rob had a complete axle in his used parts pile. The exterior is in relatively great shape. $200 bucks, an acceptable price just for that. The guts of my axle were good so the combination would make for a very decent replacement. Then we took it apart. The carrier and gears are rusted beyond usefulness. One axle is good. But hey, I don't need those parts and the bearing seats are still in good condition. For the money I was satisfied with a nice straight axle housing and a decent axle. But Rob wasn't happy, he insisted on adding a good axle so I got 2 straight axles in the deal. So, the path forward is now established. Pull my old rear end, pull the good parts. Clean and paint the replacement housing. Rebuild a new rear end. The parts to rebuild the replacement housing were purchased along with the housing.......... The path is set.
The CJ was jacked up and placed on cinder blocks and my old trusty jack stands. We've done this many times, using exactly the same blocks and stands.
This could easily be a story about how Hedgehog was found with a 4000lb CJ sitting on his chest. Believe me it was close. I had just gotten done cleaning up parts and tools from under the CJ, Earlier in the day considerable time was spent pulling the cover and inspecting the housing. I mean that Hedgehog was WAY deep under the gas tank.
All I was doing was washing down the driveway with a hose. I wasn't even touching the CJ. And the cinder blocks disintegrated. One side first then cascading to the other .....
Both sides look the same.
My poor old jack stand has had enough. Lumpy warned me at least once to get better jack stands. So listen children. Buy the very best jack stands yo can afford. 25 years ago these were the best I could afford, now I can afford better.
Part of the problem was that my old floor jack blew its seals a while ago. Friday was spent hitting Pawn shops looking for a good deal on a floor jack. Today a decent jack was found $49.00, not bad at all. Good thing I had it to lift the CJ off the ground and reset it on ..... yes blocks. I do know where a set of heavy/ taller stands are at a pawn shop.
