drifting timing (caution VERY long winded!)
elwood blues
Always Off-Roading Jeeper
- Media
- 71
- Solutions
- 1
- Export, PA
- 1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
A little background, I have a 1978 CJ7 pretty much stock when I bought it. Okay, it was bone stock except the seats when I bought it three years ago. Last spring I started this project. I wanted to get rid of my single barrel YF carb and I didn't want to spend the money or from what I read take the time to swap in a Weber. So, I picked up a really nice Motorcraft 2100 1.08 venturi carb. I bought a used 2 barrel intake from a 1979 CJ and I bought a brand new exhaust manifold. While I had the intake and exhaust manifold off I put in a new exhaust too, new headpipe, no cat, a flowmaster 40 and a tailpipe. I also stripped anything even remotely related to the emission control stuff. So I replaced every piece of vacuum line I could find, because now it's all different.
Did a full rebuild on the 2100, stripped it down to parade rest, replaced everything that could be replaced, power valve, accelerator pump, choke, float, needle and seat, everything. I also found smaller jets for it too. I got it all put together, had some timing issues initially, but got it all worked out and it seemed to run pretty well.
Until, the Ford Dura-spark module crapped out, again. So, I decide that I'm not going to replace that piece of junk again. After a lot of research I buy a Summit Racing street and strip ignition control module and matching coil. New Accel non-resistor plugs and new Taylor 8.2mm AMC 258 i6 / 4.2l specific plug wires. Plus a remanufactured distributor, new cap and new rotor. I finally got it all together and she ran. But never ran well. I never got smooth idle or drastic change in throttle response that everyone else raved about.
So, I picked up a different version motorcraft 2100, this one is an even older version. Again, full on rebuild, everything I can think of. Slap this new carb on, it still runs like
, possibly a little worse.
Last night I finally, after the CJ's sat for close to two months, got the original motorcraft 2100 swapped back on and got her fired. It's been cold here, so I had to manually adjust crank up the idle speed to keep her running for a while. It's still running like
, so I decide to throw the timing light on it, just to see.
As I listen to the engine idle up, then back down, shake and shimmer, darn near die, then idle back up again. I hook up the timing light, and stare down at the timing marks, in rhythm with the engine I watch the timing drifting back and forth. High idle, the timing reads 12 degrees BTDC, when it idles down and starts to shimmer and shake, I can watch the timing mark move down to probably 6 or 4 degree BTDC. Back and forth it goes, even after it's warmed up.
I'm completely and totally confused. After a session on chat here last night we came to a concensus that it's probably something with the vacuum advance, or a vacuum leak. If anyone else has a good idea, please let me know, I'm pulling my hair out.
P.S. If it counts for anything, I have a distinctive valve-train (I'm pretty sure it's a lifter) ticking noise. Funny thing is, as you adjust the timing more or less BTDC, the ticking noise comes and goes.
, possibly a little worse.Last night I finally, after the CJ's sat for close to two months, got the original motorcraft 2100 swapped back on and got her fired. It's been cold here, so I had to manually adjust crank up the idle speed to keep her running for a while. It's still running like
, so I decide to throw the timing light on it, just to see.As I listen to the engine idle up, then back down, shake and shimmer, darn near die, then idle back up again. I hook up the timing light, and stare down at the timing marks, in rhythm with the engine I watch the timing drifting back and forth. High idle, the timing reads 12 degrees BTDC, when it idles down and starts to shimmer and shake, I can watch the timing mark move down to probably 6 or 4 degree BTDC. Back and forth it goes, even after it's warmed up.
