Driveline popping/binding sound with video
I can certainly try that, if I can find something the right diameter. That snap ring is about 3 inches in diameter. I was pretty spent when I tried it last. You know a nights sleep can sometimes fix problems. I haven't tried it since then. I'll let you know.
Pull outwards on the shaft while you try to seat'n that ring on.
Good luck!
I see. You've already have the above done. You're trying to attach the Pinion Cage. This side is attached to the Transmission . You may need to adjust you jack and the level of the Transfer Case to get extra room. You can try to lift it as much as possible with a screw driver, just be careful. I never had a problem getting the pinion cage on. What you are actually working with is the rear transmission shaft. I would suggest putting the transmission in neutral, remove the rear cap on the low range unit so that you can turn the inner workings to line all the gears up easier.
Hey Guys,
I just wanted to post an update. It's not much of an update, since I have been out of town the last couple weeks. I had some time to take another look at the pinion cage install last night and I got it on there in about 5 mins. Amazing what taking a break does and looking at a problem with fresh eyes.
I was able to pull the reduction gear side out a little. There was about 1/4" of play from front to back and it just happened to be exactly the width of the groove that snap ring needed to seat. So once I was able to get the gear extended as far as possible towards the rear I was able to slide the pinion cage onto the gear and pull out on the gear at the same time. So as you can imagine that gave me just enough room to get that snap ring to seat. I was pushing both in last time and that was just enough to cover the groove that snap ring needed to have exposed.
So anyway, pinion cage is on, reduction unit is back on. Getting the reduction unit back on was a little tricky, but by turning the rear driveshaft output yoke at the same time I was able to get the gears to mesh and eventually got it slid on there completely. I've gotten everything back on, and the low range shifter seems to work properly and it shifts as expected.
I'm ready to reattach the rear driveshaft and put fluids in and give it a test. I think I will get all 4 wheels off of the ground for starters and test in 2wd first with an idle to make sure everything seems to be turning properly without binding. Then I will test the 4wd engagement switch and make sure the front axle turns as expected. Then I'll test the 4wd low range and make sure the reduction unit shifts as expected.
If all looks good I'll road test and report back on the popping noise under a load. Hopefully it doesn't pop and slip and we're on to the next, more fun projects like getting it trail ready with suspension upgrades, etc. Will probably do testing Friday so I'll have more information then.
Sorry for the long, uneventful post but didn't want you guys to think I abandoned the thread after all the help I've received.
talk to you soon.
Thank you for letting us know.
Best of luck!
Glad you got it back together. Let us know if that resolve all of the problems? Great Job!
Do you have a crowfoot wrench that will fit?
I don't have any of those, but that's a dang good idea and probably easier to find that a square pipe plug socket. Thanks for the idea! I might swing by advance today and see if I can find one that is the correct size.
I've had this set for almost 45 yrs.
Sears.com
A 12 point socket will work also. The device POSI showed you works good when you buy the right size container for it to fit. There are several different but same idea items to use. All gear boxes are hard to fill. You definitely need some type of pump. Here is a similar device from Amazon: https://www.amazon.com/Plews-55001-Lubrimatic-Standard-Bottles/dp/B000BQW5LK
Almost anything with a long hose attached to it that will push heavy fluids will work. You may also need it for the axles, depending on how much room you have. Lets get this thing fired up and running. I want to see if you actually fixed the initial problem.
I use the type Peanut Butter and the bottom one Posi listed. They come for the large gallon containers and for the quart size. Be careful to get the right one for your needs. I made the mistake of getting the bigger one, it worked, but when the store opened the next day I was glad to get the right size too. You don't have to rely on Amazon for it though they are generally available at your local auto parts supplier. (sorry for the minor rant that follows) Buy local if you can, it's good for your local buisnesses and some of your taxes will stay to keep your local town, village, town or city going. Everybody complains about potholes in the roads, but it seems like nobody wants to pay for them to be repaired.
hey guys, sorry for the late response! with Christmas and some of the usual crazy family :dung: that follows I'm back on it! I ended picking up a set of craftsman "multi use sockets" and the 3/4" size with a long extension took it right off. yes, I actually drove down to the local sears and bought it, after calling several local shops asking for recommendations on where to find a pipe plug socket.
PB... thanks for the link, I bought the exact same one. fits inside the quart container and works great. I'm pumped with fluids at this point, which I have to say was a larger obstacle than I expected.
road test tomorrow! my wife would kick my *** if I fired that jeep up and took off in the snow of Colorado right now.
I'm posting pics of the socket I used. PB already put a link to the pump I used, and it worked great. I recommend it, expecially something the fits into the container you're pumping from.
fingers crossed that the popping is gone and replaced by a quiet smooth running and shifting TC!
here's the socket. I got a 12piece, each of SAE and metric including the wrench, 1/2" drive for $45. worth it IMO in case it comes in handy next time I need a weird socket.
Never seen Craftsman sockets like that. Mine are 8 point for sq bolts etc.
Sears tools aren't what they used to be. Lots of different options. And the prices aren't what they used to be. I picked up a couple tool sets a couple weeks ago and paid far less than expected. Hope they are decent. Originally I was just going to pick up a couple wrenches I was needing for my "Professional" tool set. Nope, they don't make that EXCELLENT Snap-On quality tool anymore. Errrrrrr! Like the ratchet set I got though.
Hope your troubles are over and you can play with confidence.
