DUI dustributor problem
BusaDave9
Always Off-Roading Jeeper
- Featured
- 3
- Media
- 361
- Resources
- 2
- Durango, Crawlarado
- 1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
The PCV valve itself could be bad.
Pinch the hose going to the PCV when the engine is running. If the idle speed goes down the PCV valve is good. If the idle speed stays the same you have a bad PCV valve.
Better yet just replace it anyway. The PCV costs $3 and they are a standard maintenance item.
