Dustless blasting review
chris989604
las vegas
1980 CJ7 Laredo, V8, auto,
I forgot to ask,,
Does anyone have a recommendation for undercoating from a can that can go over bare metal.
I see 3m has cans ranging from $5-19 per can???
This is my other option underneath the body,, try to get all of the mud out of the cracks and the just coat.
Chris
I know you wanted to cut corners, but this type of job should never be done on the frame. I've done this job on my '64. It's not an easy job. Sorry to see this happen to you and hopefully others will lean from this. Without the proper training. One should not attempt this big of a job.
Tube removal is pertty easy, besides you most liely need new body mounts. I would also use a product similar to what I got from EastWood called Fast Etch. It converts surface rust to zinc phosphate which can be painted over. I've been using it on everything in my froame off resto. I really like it. Your results may vary. Rattle can under coating is not much better than paint. Find a good quality undercoat and spray it on with a gun. Yes you need to remove the tube, but if you don't do it at this point you will wish you had on down the road. Two guys can lift the tub off or use an engine hoist tied into the middle to remove. Hope this helps. PS: Check my profile for a couple of pictures of my frame after using the fsat etch. Rod
Doesn't look like you got a quality job regardless of the water factor.I have had three vehicles stripped with a blaster using ground walnut shell media.this removes paint and bondo.For rust and undercoating a little work with a sandblaster will take care of those areas. Either primer with epoxy primer or if you live in a area with low humididy I just kept in warm garage while working on metal.I have had good results from the 3M Undercoating in the rattle can,appling over primer. 14 years on my 1966 ford pu. in the fenderwells. Makes it easy if it's on a rotisserie
Brakes Disc
$100.00
  50.0%
