Exhaust manifold stud repair
Posi
Always Off-Roading Jeeper
New England
54 Willys 3B, FI 401, T-18, ARB Locked, Hinkey Sidewinder Winch
They are really good tips, on my new 1960 CJ5 it came with two broken exhaust bolts that are stuck in the block I have not tried anything yet to get them out. :confused:
0822
I am not a master welder... this is my assumption 2c input...
be careful when welding close to the block. The weld will be (99% positive)
much hotter than the engine ever gets. You are risking warping some s:censored:t
I would do very small, quick, and spaced out (time wise) tack welds if you are planning to try this route on the actual block bolts.
~ JR
X2,
If the bolt is flush to the block drilling out the stud and using a quality extractor may be the answer. Don’t use too much force when removing or it could break and cause a bigger issue.
By the way Posi... :notworthy:
That is a GREAT looking engine friend!!! :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool:
Did I mention.... :drool:???
Can't wait til I pull mine and make her shine and run like new...
~ JR
Since I have never had any luck with easyouts or others I might drill them out and retap them. Thanks fo rthe help.
So Jealous right now... :notworthy: :drool: :notworthy:
Your welcome, good to know you found it helpful.
