Exhaust stem, what is it?
b3uhbp
Arlington, TX
84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
That was part of the Pulse Air System. Basically it cross fed information from the exhaust upstream and downstream of the catalytic converter and fed into the now famous emissions systems of the late CJ 258s.
Since you have the HEI and the weber, it wasn't needed, and removed. Should be plugged tight though.
I don't know if it's causing your chugging or not.
I assumed it was emissions related but it's good to have some specifics. I will now move to plug it tight. Not sure how to achieve that but will do some research.
Thanks for your expertise and quick response.
That goes directly to the 'cat'.
YES-part of the SMOG system.
How would you go about plugging it completely?
You could remove the cutoff piece, fold it over and weld it. Actually, whatever works. Leaving it open could allow cold air in and warp a valve. I assume that all the emissions stuff is long gone.
See if you can pinch that tube shut.
Yes, all the smog junk is gone. It's not wide open. There was an attempt to block it as there is a hard substance in the end but it's leaking. I'll remove it and check for next steps.
