Factory equipment?
Factory equipment?
thiswontbetooexpensive
Full Time Jeeper
Madison County, TX
1980 CJ5, Stock and original
258I6, Dana 300, T 176
(poor thing needs a little bit of time and a few kind words)
What pin are you talking about?
The one that is held in place by the hose clamp. Holds the gear shift to the tranny I'm guessing
If you can't see the picture, I can try and PM it to you.
There is no pin that holds the shifter on it is held in place by the piece on top of the Transmission that goes around the shifter.
There is no pin that holds the shifter on it is held in place by the piece on top of the trans that goes around the shifter.
Thanks mtnwhlr. That's what I was thinking too, just wondering what purpose the hose clamp was serving. I might take it off later when reassembling and see what happens.
is that hose clamp holding #39 (pin) in? if so yes you do need that pin there. somone probably put the wrong pin in. it holds the colar in that holds the shifter in. #32
somone rigged it up. mine has no hose clamp. the pin is pressed in
Thanks. I will investigate further when i get back up there again. Working on rear axle now. Again, thanks for the input!
Clean it up and use some high strength LocTite.
Nice :D
I learn something every day.
Nice :D
Me too! I went to order the part you had suggested because I could see it on the diagram. Then, I got to looking at the picture again, then back to the parts diagram and it appeared somthing was missing.... Google Images to the rescue!!!!
Back to the parts diagram, and bingo. 17 or 18 bucks later and wait on FEDEX. Took all of 45 seconds to get these changed/installed. I thought there might have been something missing to repel water, that was the secondary function of the rubber boot I guess!
Thanks to all who provided assistance with this :notworthy:. I will be back again soon with another question...don't worry!!!!!
Life is full of small victories, thats what keeps us wanting to be challenged I reckon:rolleyes:.
