Fluids.
Fluids.
Cduke88
Poth, tx
1984 cj7
The use of ATF in the late model CJs was a big screw up by AMC. For the tranny and Transfer Case use SAE 85-90 wt gear oil. For flat towing, the tow bar set-up will work, I would advise dual chains also. The owners manual states for manual Transmission is to have the hubs locked, t-case in neutral, tranny in gear, steering wheel unlocked. Then every 200 miles to run the engine for one minute to lubricate the t-case. Or drop the rear driveshaft. After flat towing for a while you can feel just how warm the transfer case gets as it is poorly lubricated during flat towing. A good front wheel alignment helps and have the tow bar mounted level or down a bit on the tow ball end. Don't slam on your brakes either as the forward momentum can break the hold down mechanism on the tow bar. You are towing a vehicle weighing around 4,000 lbs with no trailer brakes.
Edit: Looking at your pics, it does appear that you have locking hubs in the rear. So you could just unlock those suckers and flat tow all day long.
I wish they locked. Just hubs. Do you need to lock front hubs if you drop driveshaft? That is my main concern.
Sent from my SM-N950U using Tapatalk
When I first got my 8 it had some kind of heavier gear oil in the T-5 . It regularly ground the 3-4 shift unless I gave it an extra second or two between shifts. It was also hard to get into gear when cold.After reading a ton of differing opinions (all of which have merit because it worked for them) I chose Synchromesh. No more grinding,regardless of how fast I shifted, it was easier to get into any gear (hot or cold) at any time. Cant say enough good about the stuff, and it greatly improved the driveablity up until I pulled it for a T19. IIRC 85/90 GL4 for the Transfer Case
In the T-4 /T-5 use 75W-90 syn gear oil(I use Valvoline in mine).
AMC used ATF, against Borg-Warner's advice and burned up many T4/T5 trannys. BW would not warranty them, and AMC had to 'eat' those losses.
AMC had a special 'stink-oil' for the T4/&5 that hasn't been made in 20 yrs. I still have a case of it.
Do you have an LSD in the rear diff?
Otherwise, just std weight gear oil.
I drop the rear DS at the pinion, and no hub locking is needed.
Just remember to unlock the steering wheel.;)
