Flywheel Question
Oldguyinajeep
- Media
- 9
- Derby, KS
- '86 CJ-7 258ci 4spd Dana 30 and 44
Howell TBI Fuel inj, Headers, Dual batteries, Warn winch/air compressor, rear
disc brake conversion, Detroit locker (rear), Eaton E-locker (front), 4:10 gears, 2.5 in Rancho lift, 1" body lift, fully armored, 35" BFG KM2s, Warn front hub conversions, line locks front and rear, roll cage, warn front bumper, rock hard rear bumper/tire carrier, DUI ignition, dual electric fans, LED rock lights
Been having nasty starter to flywheel noise for awhile now, and it has recently worsened. Gonna pull the starter and get a peek at the ring gear, but I'm pretty sure I know what I'll find. So...I've read the related posts on this forum and others and have been looking at videos. Looks like a neat project. But I'd like some opinions regarding:
1) Is it necessary to shim the flywheel after having it resurfaced. One video was adamant about this, but it doesn't make sense to me that a couple thousandths could make much difference, and most sources don't even mention it.
2) I've got a perfectly functioning centerforce clutch and pressure plate. Should I not even bother getting the FW resurfaced, or just put it all back together with new bearings? Alternatively, could I resurface and just replace the clutch disc? Can a pressure plate be resurfaced, and should that be done?
3) I guess I'd be okay with replacing everything, but I'm not really sure I'd go back with a centerforce. Mainly because of cost. I've read good things about the Luk clutch set, and would consider it, especially at about a third of the price of the CF,
4) In one of the many posts I read, Lumpy recommended keeping the stock FW, as opposed to buying a new one (I assume it's better quality), and keep the bolts (because of length issues). Some sources say to always replace the bolts. Thoughts?
5) Lastly, would you have a FW balanced at the time of resurfacing? Some high performance forums even advocate balancing with the clutch and PP installed (a little over-the-top for me)
As always, your input is valued and appreciated. Thanks.
