Freeze plug sensor removal
Jcminto
Petawawa, Ontario. Canada
'77 CJ5 - 4.2L I6, T18,
Dana 44 rear, 30 front,
Good day all, in a jam. Still trying to finish my 77 before the snow flies, (its lightly snowing right now....)
I just added the Mojave heater core, plumbing looks good, blower works, pictures to come,
I wanted to add a block heater while I was at it, my block has 3 freeze plugs all drivers side. the only real accessible one in the rear one which appears to have a temp sensor, two questions...
do I require this sensor? its not hooked to anything, and if not how the heck do I get it out?
I should mention that the post that the sensor used to plug into is broken off, so its NS already.
as always, any help is much appreciated.
When I remove soft plugs, I hammer with a punch on either side of the plug and try to get it to rotate. Then pry it out with a screwdriver.
The other two are just normal plugs, I punched out the front one, pulled the steering pump and placed the block heater their, not ideal but all I could do.
Time is Limited for me as it is, and my other car just died, so the jeep has gone from fun project, to might just be my daily driver....
