Front diff help
Front diff help
tireman74
Celina, Texas
1982 CJ5
4.2L i6 258
T-176
Dana 300
AMC 20 rear and Dana 30 front
49 is number of the ring teeth and 18 the number on the pinion gear. 49/18=2.72 gear ratio. Not sure of the other. Maybe axle code/serial #.
So there is 49 on the ring and 18 on the pinion? And the 2.72 is the ratio. I didn't realize that was a dot between the 2 and 72, just thought it was a spot of rust I didn't get cleaned off. Thanks for the help!!
That's the base gearing for the years we have. Not sure how much you know but basically its 2.72 turns of the drive shaft to turn the tires once.
I off road a lot so I changed my gears to 4.56 to improve crawl ratio.
