Gronk MC2100 linkage issues.
Dan77CJ7
Denver,303Local
76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
I started the MC2100 install and i'm running into linkage issuse. and need some brain storming, if anybody have pics of the linkage, Down pull or what ever you did. i have a huge brake booster HUGE!!!!!!!! my new air intake has some kinks what do you guys think? thanks for the 2 cents. BTW everything is dry fitted.
Do you have the stock linkage still? I made a small arm that I used to pull the linkage down. I'll be in the shop tomorrow and hopefully I'll remember and post some pics of it..
NO linkage never had it, no carb when i got the jeep. so i got the weber and intake at a swap meet i did have the throttle cable the bracket im using was a box of parts i found at the flee market labeled "Jeep :dung:" so nothing works on the MC
Up try to get some pics tomorrow of my set up. It was on a 84 Cj.
did it not come with all the proper linkages..the only thing i heard is the linkage hits unless you have that thick felt spacer-gasket
I thought I had some pics of the linkage I came up with but to teel the truth it is nothing to brag about. Thanks for the reminder that this was another "functional" system that needs some "polish".:D
the nut that the bar attaches to is anther ball, I think i got it from either 2100 carb or the stock carb. one of the 2 had a screw in style ball.
I just popped a V8 throttle cable from an 80 CJ7 with V8 on my MC2100 swap. No linkage required. Goes straight to ball on the carb.
$45.00
  22.5%
