Engine HEI problems.
sewrig01
Louisville, KY
1979 CJ 5. Stock 4.2L, Dana 20
I'm not sure if I messed something up or just have bad luck. I replaced my distributor with an HEI distributor. The jeep will start and idle. However, if I adjust the timing to what should be proper, it has trouble. Once I reattached the vacuum tube it starts racing.
This may be a separate issue, but additionally I have smoke in the engine compartment and the exhaust was red. I don't know if something failed such as my EGR and it's just bad timing or if there's a problem with the HEI install.
At this point I would like any suggestions what to even consider. My Jeep was disabled last Winter when I could have used it in the snow, I don't want that to be the case this Winter
What's your timing set to?
Also what engine?
Are you able to clearly see the timing mark? Before I replaced my old timing chain, I could never get TDC because the mark would shift or disappear.
I feel like I'm on the way to having this sorted. I do have a follow-up question. If anybody cares to chime in. How important is the orientation of the distributor? The new one fits but it does not seem like it can rotate to where it needs to be for timing. Is there any reason that I'm not understanding that we should not adjust it to where the rotor points more outward at top dead center? Also does does it matter which plug on the cap points to one as long as they're in the right order and number one is firing a top dead center? Logically, it seems like that should be the most important thing, but I'm worried that I'm missing some key aspect.
If you can't rotate the distributor because of interference you can always pull it, and rotate to another tooth to give you some room.
As for the plug wires on the cap, you are correct. As long as the #1 wire is to the location where the rotor points at #1 TDC the location on the cap doesn't matter as long as the correct wiring order follows in the correct rotation.
Ok , so I tried to fix this tonight. I made certain it was TDC of the compression stroke. Positioned the distributor where #1 was pointing to a good location. (able to have room to adjust). I bolted it enough that I could move it, but that it wouldn't slip due to vibration. Then I made certain that the Vac advance was not connected and started it. I managed to get it running at about 900 rpm at 6deg. (this is where it was smooth, but not revving too high. My sticker says 6@700, so I may need to adjust the idle. ) However, as soon as I put the vacuum back on the engine raced. I checked a few more settings, but it always raced when I connected the vacuum advance. The exhaust began to glow red, so I stopped. I am leaning toward believing that I have a defective distributor. (It ran fine with the oem setup and I know that the vacuum is manifold vacuum).
II think that I will try to reconnect the original hardware next, but I welcome any insight.
Thanks for all of the comments and help.
Really sounds like your dist is going to full advance as soon as you connect the vacuum. Not good...
I believe you are correct.
Do you have a light with an adjustable advance? Would easily let you know but not really needed. https://www.summitracing.com/parts/sum-g1059
Timing is still too much. Have you checked for vacuum leaks?...both in the dist. and everywhere else. Timing and vacuum leaks are the two main reasons for fast idle and lean burning.
    Best for votes
    on specific items
