holley rebuild
mylittlecj5
RIP Mike, we'll all miss you
- OKC area
- '74 CJ-5,
360 AMC Engine.
35x12.50x15 TSL Super Swamper tires.
In a frame off rebuild for a long time...
Just hose running up off the vent tubes of the bowls, you run them vertical into the air cleaner, up near the top of the air cleaner bolt. You tie them up on the bolt. But leave enough room for them to breathe.
I cant find a pic right now...when your bouncing around on a trail, it keeps fuel from splashing out of the bowls and down into the carb, making the motor stumble (and stink).
so you just run fuel line up them. thanks for the idea![]()
The Holley Off-Road Truck Avenger has this built into the carb. Look at the top of the carb at the upside-down U shaped tube with holes in it. That serves the same purpose.
