Hood Louvers
Hood Louvers
BusaDave9
Always Off-Roading Jeeper
Featured
Durango, Crawlarado
Good Ideas
Thanks Old Dog!
They certainly are not going to hurt anything. They have been on my to-do list for a long time.
I found some on the Quadratec site for a decent price. They have metal and plastic units in powder coat and SS. I am getting them for my project as well. I like how they look and the air flow will help alot.
I had the local rod shop punch my louvers in the hood. It cost me $2.00/louver. It took forever to get done. Since this was my baby, I sprung for 40 of them. Came out awesome.
HINT!!!
If you decide to get louvers punched, DA the hood with a sander first where louvers will be punched!!! Easier to prep the hood for paint without louvers then afterwards. :chug:
HINT!!!
If you decide to get louvers punched, DA the hood with a sander first where louvers will be punched!!! Easier to prep the hood without louvers then afterwards. :chug:
Thanks for the advice cjbilly.
Can you post some pics?
I run "Run Cool" hood louvers on my CJ7 . They fit in between all hood supports on top and I have a set on the side of the hood. They are made of aluminum and pop rivet in with stainless pop rivets. Google Run Cool for pictures.
Looks good Dave :chug:
As a general rule why not mount the louvers so they are pointing towards the front and "scooping the breeze" like they are mounted in the HMMWV?
I think the idea is to let the rising hot air out. You should be getting plenty of air coming in through the grill. But the hot air gets kind of trapped at the hood. Maybe the cool incoming "breeze" you mention would push the hot air down and out under the body, but I don't know.
I am not a scientist or engineer. I am just going by my gut in this response, so take it for what it is. ;)
My CJ runs hottest at crawling speeds, so the idea behind my louvers is to let hot air rise out of the engine compartment as it is idling along.
At normal driving speeds, there's so much air circulating under the hood that louvers are generally pointless.
I know this is an old thread but wanted to say that I too want to install some louvors or scoop in my CJ7 . Anyone know of what type of mechanic or fabrication shop that can do it? Or is it simple to diy or purchase online? In that case, Any printable/viewable online diagrams?
Great writeup! :notworthy:
Try this thread. This is the thread I did on installing my louvers.
http://www.jeep-cj.com/forums/f7/louver-install-23533/
There should be enough information for you to do the job yourself.
About the direction of the louvers. While watching one of the hotrod shows the other day they addressed the issue of cooling under the hood of a race car. They installed holes or ports to reduce "air stacking" under the hood. Cool term "Air stacking". The next time this comes up I'll show my smarts by using the term.
  • Locked
