How do I? I have a 1969 CJ-5 that the ignition switch keeps rotating in the dash. How do I fix that?
Finno7
Cave Creek, AZ
1969 CJ-5
I have a 1969 CJ5 that the ignition switch keeps rotating in the dash. How do I fix that?
The ignition bazel has a slot. The ignition switch has a small tab that slides into the bazel slot, Everything is held tight and in place by a compressed spring. The spring could be worn which causes the bezel and switch to move.
Hold the bezel and compress the spring by pushing the switch towards the dash, while pushing it in turn left to slide the tab out of the bezel slot. You could try to add a couple washers to help the spring hold tight. Hope this helps.
Holy :dung:. It's @Posi So long...
How do I? Oil seal
