ignition coil question
Jeff Kavanagh
- Owen Sound, Ont., Canada
- 85' CJ7, straight 6, D300, All I know so far about he transmission is that it is a 5 speed manual. Still trying to learn what everything else is. lol
Hello again.
Coming out from my ignition coil I have three wires. A green one and then two red ones out of the same terminal.
One of the red wires has been disconnected from something. I can't find it to save the life of me.
Now looking at a drawing I found it seems that both of the red wires go back to the key ignition. The green one to the ignition module.
I haven't put gas to it yet and so far the engine turns over well with the key.
I have put in a new solenoid, starter and battery. I checked the distributor and it seems very clean and the rotor seems to move when put power to it. I also put new plugs in it.
I guess my question is, am I correct in assuming that the second wire goes back to the ignition. If it does I guess I am going to have some fun trying to find it. (knowing I won't I will likely have to get some help in)
Should I try and put gas in the carb at this point to see if it fires?
I have the gas tank disconnected right now because it needs to be changed and I don't want bad gas getting in there.
