Ignition Upgrade
WAXER
- Baltimore
- 1986 CJ 7, 258 I6, 5 SPD, No MCU, No Ignition Module, No emissions.
My 86 CJ7 AMC 258 i6 / 4.2l , I guess at one time had the Solid State Ignition distributor? It now has a points type dizzy (1) ground wire (1) to coil. I was told there is nothing wrong with a points dist, just change points,cap,rotor. Since I have no idea what type/make dist it is, it will be difficult to match something up. If I were to upgrade to an HEI type dist (3) wire, would I need an ignition module? All the wires are cut on the one under the coolant resivior.
that goes with the factory ignition system, that way you know what you have and you won't have spliced wires going everywhere. if you sell it later you won't be the po that made a bird nest out of the wiring.
