Is my cam off 180* ?
yellow85cj
- Featured
- 1
- Media
- 3
- Resources
- 1
- Solutions
- 3
- Ft Worth,TX
- 85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
Had a previous thread with my timing problem. http://www.jeep-cj.com/forums/f2/vacuum-advance-problem-28683/
After fooling with it for hours, resetting the distributor countless times, the only thing left was the cam.
So here's what the cam/ crank gears look like. The cam gear mark is 180* out from what the FSM shows.
Is it possible the the engine would run with it 180* out? Just couldn't get it timed correctly, with or without vac advance. At higher rpm's would miss and backfire, no real power. Ran fine at low rpm's set at 8*. And at lower advance timing, even at 0*
Am using the large cap and rotor so got a cheap cap and cut a hole above the #1 contact. With the timing light the rotor appeared to be firing between #1 and #4, never could seem to get it close to the #1 contact.
Yes, it is at TDC as the cork really popped when I cranked it to the right spot on the balancer.
Any opinions?
Any opinions?
