Is this a T4 or T176?
cuban11182
- CORPUS CHRISTI
- 84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
I'm asking the guy now for the Transmission , adapter, and front and rear drive shafts. Lets see what he says.
If you plan on putting this in your Cj you'll need the bellhousing for the T-176 as well. It has a different bolt pattern. If the deal includes that Dana 300 thats still bolted to the Transmission WOW! Thats another $200-$250 as well.
GOOD LUCK
Pete, you let me know when you have a good one for sale for $350. I just may be interested. Now isn't a good time but in the not so distant future I'll be in the market for a spare.T-176 . Great deal for $100. I sell them for $350 in good operating condition
Yes, I believe I read the same thing that Torx said. A T-4 /T-5 bellhousing can be drilled to fit a T-176 . So 2 driveshafts is what would be needed to convert to it.
BTW you should check the metal tag riveted to the case for the number. Most I have come across are T177's.
