Is THIS my problem?
Is THIS my problem?
Vvajk
Idaho
1984 CJ-7, 4.2L inline six, T-5 Tranny, Dana 300 2 stick T-case, AMC 20 rear axle, limited slip diffs.
Can you tighten the screws any?
CK all the carb screws and manifold bolts for tightness.
I found a carb guy on youtube that says over tightening is actually one of the causes. I'm guessing I need to buy a new seal. I'm also wondering why a little RTV wouldn't solve the problem?
buy a gasket/rebuilt kit their only $25
Yeah I agree with Posi,
Gasket maker / RTV is great, don't get me wrong, but not for Carb unless emergency trail fix.
?X on the carb kit! RTV+gasoline=problems. It doesn't usually last for very long.
"I like trail fixes, especially on somebody elses rig.":D
I agree with the rebuild kit idea.
Rebuild kit for sure and if its been a while a new fuel filter.
First-see if the screws are loose.;)
Yeah, I will be probably buying a rebuild kit, which will be new and scary territory for me. But, this is how you learn right?
Do you guys think this is why the Jeep has been a pain to start lately?
Check the flatness of the accelerator pump cover after you get it torn down.
Maybe I am not seeing what the other problem is,but I DO see fuel squirting from the accelerator pump diaphragm vent hole.This is do to a faulty pump diaphragm. New diaphragm supplied in Kit along with other parts that wearout. Accelerator pump probably not funtioning very well.
The only trail fix would be to block off fuel between carb and diaphragm with a appropriate material then reinstall cover .:) mike
So that's actually a vent hole of some kind it's coming out of? It didn't start squirting out till I opened the choke . . .
Thanks JR, useful info
Side note: I just noticed I inadvertently posted a pic of the modulator diaphragm instead of the pump diaphragm sorry for the confusion.
Vvajk, there is a vent hole on the pump cover just below the pump lever. However, after looking at the video again the leak looks to be coming from the side not the vent. The pump diaphragm is toast and needs to be replaced with a rebuild kit.
Gotcha! Thanks everyone for your input. I'm kind of scared to do it, but it's nice to know I can always count on some help from the best forum ever! :)
    Best for votes
    on specific items
$45.00
  22.5%
