Build Thread Jr's 74 CJ5 "fix" and build as I go...
re: Jr's 74 CJ5 "fix" and build as I go...
JR,
Go to OMIX-ADA FALL BONUS BUCKS REBATE I guess they own Alloy among others. Should not matter where they came from.
I got my axles through Base 4x4 outfitters, but were shipped free from Omix-Ada ,
cheapest I could find.
:notworthy::notworthy::notworthy:
Cheers man! Thanks!
$20.00 coming my way! ;)
~ JR
Hey! Good for a drink or two, glad I could help!
Oh yeah, at rite aid that will almost buy me a 30pk of bud light :D :beer:
was about to go with where you did because summit lagging on the ship date, but i called them and even though they say they are in stock online, she said they are backordered unitl she don't know when...
grrr... :madjeep:
Looks good JR
Nice, the PO when they did mine didn't use the existing hole and extend the sticks to it, the cut a new gaping ugly one in the floor pan!
Been a While again. Got a bunch of parts and mods coming up and in.
This 4th of July weekend, I'm heading to the Rubicon trail. The mads / parts I'm installing before hand are:
3- Tie Rod / drag link flips from Goferit.com
New (working) speedometer
1-1/4" Spidertrax Wheel spacers on the front wheels
Heavy duty steering brace arm from Extreme Custom Fab
That and some minor checking up on everything else, packing bearings etc.
Then after the trip, I'll be installing:
My new CJ to YJ Old Man Emu 3 - 3-1/2" Lift suspension kit from Rockyroad outfitters (new suspension from front frame to rear frame)
My new SM420 Transmission and adapters
New Hydraulic clutch conversion
Centerforce Dual Friction clutch and through out bearing kit
Rebuild kit for the Dana 20
Modified rive-lines re-install after tranny swap / lift.
After all this I'll see how everything is working together. I'm going to try to avoid drop pitman arm and Transfer Case drops.
Pictures and posts to come.
~ Jr
I'll be following this build up for sure. We're going to be using some similar mods. I think you can probably get away without the drop pitman arm. The Transfer Case drop is going to be the tough one. Can you clock the Dana 20 the way alot of guys do with the Dana 300 ? :confused:
not really that i've seen anyways... but I have the double cardian joint (like tom woods) rear shaft, and the ability to cut and re-weld the spring perches again if need be to point it up right. The TC output should be facing directly straight back for that style (as far as I know) and the Pinon shaft at it (off a few degrees) So far from eyeballing it last time ;), I have no noise or problems with it.
~ Jr
Jr. on my 83 with a 4" lift, when I did the rod end flip, I was able to use my stock arm.
:laugh:
Yeah i was plugging it a little on the 4th.
But for the most part, no one was kept held up.
I had already done the tie rod flip before this... I'm thinking the lift kit may help some, as will the lower gears so i'm not "bouncing" over everything :cool:
~ Jr
The gears and the O.M.E. lift are going to make your day trust me. Glad to see you and the rest of the "Red Muscle Shirt Riders" had fun. :D
Yeah us clampers like our Red... Everyone else just seemed to fit in with us...
:D:D
~ Jr
Jr. looks like it's time for the ford shock tower up-grade.
I have new shock mounts that came with the OME lift kit / YJ conversion kit.
:cool:
Kinda reminds me of the ford shock tower when looking at them before...
I'll have to check both out.
:cool:
:cool:
:cool:
Thats what I thought to when I was looking over the kit. You may have to get us measurements. ;) So your done wheeling for a bit huh? :(
I plan to do a pretty detailed install / review thread as I haven't seen any on this product yet. Or install posts (i've been searching to try to be ready for "everything...") :cool:
I know they are definitley taller. By around 5" to 8" or so. They remind me of the ford towers.
I can tell you so far from looking at that kit, everything looks really beefy and awesomely made! It appears to be a very nice quality kit. The brake extensions and shocks don't appear to be "top" quality, but they do seem like they'll work.
A little bit... :cool:
I'm hoping to get the SM420 and all the other goodies in soon, then I'll be putting her under the knife.
Hopefully when done, she'll be all ready to go for another trip. going to do a few test trips to the local OHV park to test some stuff out first and get used to it (new tranny / gearing and lift tilt points)
Should be great! :cool:
~ Jr
