low oil pressure
kidd79
Bite the bullet, pull that head off and have it rebuilt or rebuild it yourself.
Biting now. :-\
10-15 at idle when warmed up is liveable..A little higher would be nice but we all know that with bearing wear oil pressure goes down..We use to add a quart of automatic Transmission fluid to the oil a couple of hundred miles before changing it to help free up sticking lifters..To help clean out the combustion chamber we would trickle a quart of water through the carb while running..To boost the oil pressure due to wear you can add a quart of Lucas oil stabilizer at oil change..most of these are old mechanics tricks but they do workGot the motor swapped out. Tested it yesterday evening. The Ol CJ7 is alive again. Runs fairly decent. Still have a few odds and ends to sort out. But all in all it'll be a good hunting rig for my dad this year. Oh and after the motor got up to temp the oil pressure stayed around 10-15psi. Is that normal? My yj has a carbed AMC 258 i6 / 4.2l with the same intake and carb as the cj but it runs around 40-50 at temp.
Your oil pump could have lost its prime. I have seen this a few times. There are some good treads on priming the oil pump on this site. I had one that I moter I was working on and thought it I must have had more problems than I did after fully priming the oil pump manually all the oil pressure came back. good luckGuys. What are all the causes of low to no oil pressure in a AMC 258 i6 / 4.2l , besides the obvious no oil, bad oil pump and sending unit that you have run across? I had a rocker arm slide over and the lifter and push rod came out of the head for instance. I'm trying to gather as much info as I can, cuz I have a AMC 258 i6 / 4.2l right now in a 81cj5 that's not making hardly any pressure with a full oil pan. It's got a brand new mechanical gauge, and you can see the oil barely moving up the clear tube while it's running..I just bought the jeep and have no histor on this motor. Looking for a good place to start troubleshooting since I'm out in the gulf of Mexico and won't be home for another 2 weeks.
Thanks.
What pressure were you running after prime?
During prime I was making 62psi when the oil was cold. It was in the 50's outside that day. After installing the motor initial crank oil psi was right at 60, and while running it to set the timing and check over everything the engine warmed up to around 170ish and I watched the oil pressure drop down while the motor was warning up. It ran fine at temp at 180°@10-15 oil psi
My old Mopar Performance engine book (written by the chrysler engineers) quoted that you would want a minimum of 10psi oil pressure for every 1000rpm so 10-15 at idle warm is livable, the AMC V8 has an aluminum housing around steel gears for an oil pump. aluminum expands more than steel increasing the clearances around the oil pump gears, one of the reasons your oil pressure drops with the rise in engine temperature to me I think you are good to go enjoy your jeep![]()
