Manual Transmission keep jumping out of gear...
Airstrike
Jacksonville, FL
1978 CJ7 full old school glass body including grill. 304 w/T-18A, Dana 30 and 20.
Sounds like it is time for a rebuild.
It can be a synchronizer, or it can also be in the top cover. If one of the rails gets broken or if the springs under the balls rust and break they can allow it to jump out of gear.
Or it could be too much end play, bad motor or transmission mounts, no or bad torque stud, misaligned clutch, as well as other things. I would pull the top off and see what’s up if anything; easy to do through the cover in the floor. If everything looks good check the mounts. With a CJ Dana 20 when in 4L the shifter should be forward almost to the floor .
$45.00
  22.5%
