MC2100 jet issue??
MC2100 jet issue??
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
OK so happy humbug everybody!!
I have been out in the shop all morning with the CJ, specifically the new /old/rebuilt MC2100. I got the vacuum leaks under control and have it running fair smooth, It would be better I think if I could use the EGR valve but the header kind of did away with that option, at least for the moment.
OK so to the point, finally, I don't seem to be able to idle below 800 RPMs.
I am kind of thinking I may need to swap the jets to something a bit smaller, any opinions??
Before you ask, I have no idea what size they are right now I payed no attention when I built the carb. It is a 1.08 and it came off a 60s galaxy so it does not even have a bowl vent. the timing is running off the ported vacuum at 8 BTDC.:cool:
I guess the question, really is, you guys that have made the swap and decided to lean out the jets, what indicated that you were too rich? I am guessing it was the idle situation I am describing.:beer:
OUTSTANDING!!
thanks Elwood, I kind of thought you would have something to contribute.
How much do I want to drop the size? is .003 too much, is .001 enough?:wtf:
i got 46 in mine with no problems. my idle is about 600 to 700.
