Build Thread Mike's 1986 CJ7 (Mid Year) Rebuild
Get rid of that plastic fuel filter. It's a fire hazard, especially above the exhaust manifold like that.:eek:
When doing ANY wiring mods. Disconnect the battery POS(+)lead before cutting any wires. Most circuits are still 'hot' when the ign key is not in place.;)
Yeah, I know. Picking one up tomorrow. I've got to find out where the vent line from the fuel filter to the tank went.
I thought you always disconnect the negative...
Very very nice!
Thanks...
Current flow is NEG(-)to POS(+)in DC circuits.
I disco the POS(+)because the whole Jeep frame/body is NEG(-)and a lot less chance of a short.
Looking great! What is left?
Thanks... was just looking at yours... getting exciting!
I'm working on this stuff right now:
https://www.jeep-cj.com/forums/f49/unresolved-build-questions-engine-compartment-27272/
They don't make the charcoal canister any longer, so trying to figure out what to do... right now concentrating on the items in the above thread.
Still have misc. bolt checking stuff... fluid stuff... electrical stuff... some aesthetic stuff... seat belts... storage... bikini... investigating upgrade to power brakes... Rush upgrade on distributor and wires (will wait until I'm sure everything is working as it is)...
Noticed something loose the other day and had time this morning to investigate.
Thought it was the front U-bolt spring nuts, but checked torque and all 16 okay according to the manual.
Discovered that the steering stabilizer mount is loose, but can't figure out how to tighten. Can't imagine it is supposed have play between the springs and axle.
The driver side of the stabilizer mount that runs up from the stabilizer and between the top of the springs and the bottom of the axle has some play. I don't see a way to tighten it. Like I said, the U-bolt nuts are torqued to 55 ft/lbs.
Any help on this one?
Other news:
Who the hell cross threads a shifter knob?! Picked up a couple of stop nuts and went to thread them on and found the main shift lever threads all boogered up. Ran a die and reformed the threads. Chased the nuts and shift knobs and all is now good. Got new shift pattern emblems on the original knobs.... man, that looks good.
Had trouble with the Transmission engaging yesterday. Moved the 4WD shift lever through its pattern and then found that the main Transmission would not engage (acted like neutral). I had it in 2H but had no forward or reverse. Moved it to all positions and no change. Kept monkeying with it and the Transmission finally engaged; both forward and reverse. Problem is; I don't know what I did. Is there a sequence that I'm not aware of. I've never owned a 4WD anything.
Moved the rear axle vent higher up... the hose was hanging too far down in the wheel well. Found it when I was cleaning up the right rear taillight electrical connector...
Installed a new cowl vent gasket.
Installed new Rugged Ridge floor mats. Cut the hi-lo beam switch hole with a forstner bit... worked great. Mats are a perfect fit... highly recommend. The RR logo peels right off... didn't like them anyway.
Found that the heater intake door isn't working. I plan on doing a complete refurbish anyway, including the Blazer motor upgrade and making all new gaskets.
Spent yesterday doing mindless stuff... even installed a new set of caps and bumpers on the spare tire carrier...
I'm going to do more mindless stuff today... Jeep cowl decals and tailgate seal.
My Transmission lever didn't have boogered threads - they were gone. Someone must have cross threaded that one cause whoever removed the knob took the threads with it. Twisted em right off. So I guess the same person that cross threads one also thinks it takes a gorilla to remove it.......
Had trouble with the transmission engaging yesterday. Moved the 4WD shift lever through its pattern and then found that the main transmission would not engage (acted like neutral). I had it in 2H but had no forward or reverse. Moved it to all positions and no change. Kept monkeying with it and the transmission finally engaged; both forward and reverse. Problem is; I don't know what I did. Is there a sequence that I'm not aware of. I've never owned a 4WD anything.
With the Transmission in gear, clutch in, complete stop for 4 wheel drive low. Same when going back to 2 wheel drive. Sometimes this feels like it's sticking, in that case a little wiggle the Jeep with the clutch, may help it engage and disengage. For 4 wheel drive high you can do the same thing or if you moving at a low speed you should be able to shift into 4 wheel high no problems. If you encounter a problem then use the process for 4 wheel low. Low speeds is below 20 mph.
I would be checking the oil level in both the tranny and t'case PDQ.
With the transmission in gear, clutch in, complete stop for 4 wheel drive low. Same when going back to 2 wheel drive. Sometimes this feels like it's sticking, in that case a little wiggle the Jeep with the clutch, may help it engage and disengage. For 4 wheel drive high you can do the same thing or if you moving at a low speed you should be able to shift into 4 wheel high no problems. If you encounter a problem then use the process for 4 wheel low. Low speeds is below 20 mph.
Thanks... must have done some of that unwittingly and got it back into gear.
I plan on changing fluids in both and differential in the next month... already got my fluid pump. Have to figure out what types go where. Any suggestions?
Also will be flushing brake lines.
Syn manual oil for the tranny, Std 80-90 gear weight oil for the t'case, and axles.
I do STRONGLY recommend to you. To find a copy of the factory service manual(MR-252).
I would NOT drive it, till the oil levels have been ck'd. You want the oil to be at the bottom of the fill hole with the Jeep sit'n on level ground.
I've got the manual... thanks.
Thanks for the info.
