Build Thread Mike's 1986 CJ7 (Mid Year) Rebuild
mdeluca
Full Time Jeeper
- Featured
- 2
- Solutions
- 2
- Hickory, NC
- 1986 CJ7, 258, T5, D30, D44, D300
Team Rush parts arrived... BWD baby,,,
off quick, but noticed that it had eaten some of the paint on my steering shaft. Rinsed all of that off. So now I've got to figure out what to do.
Thanks, LG. I already had compressed the "v's" at either end of the bale and it is holding down now. Still have to do a test drive, but I think I've got that sorted now. I'll use your method next time.Have the brake fluid about 3/16-1/4" below the top of the MC reservoir.
CK the seal for splits etc.
With the cover spring in the vertical, without the cover, push down in the center to increase clamping force onto the lid. I have to use a screwdriver as a 'pry-bar' to release the cover on mine(mine don't leak).
Thanks…That engine compartment is beautiful !!!!!!!!!
Thanks…Very nice inside and out!
Thanks...Very nice looking CJ
out of me. Glad I left on the loosened body mount nut in the center of the plate.Yesterday I decided to change the fluid in the transfer case and transmission. Got under there and the access hole in the belly plate does not align with the transfer case drain plug. I watched a youtube video and the guy said you had to remove the belly plate so I set about removing it. Got down to the one bolt on either end of the plate and the body mount. Took one of the remaining plate bolts off and the tranny/case sagged down. Scared theout of me. Glad I left on the loosened body mount nut in the center of the plate.
Centered my floor jack on the plate and raised it up to get the bolts back in. Called Adam and he said to use a block of wood and support the bell housing with the floor jack, then remove the plate… so I'll be doing that this morning.
Thinking about enlarging the access hole in the plate so that next time I can get to the transfer case drain plug.
I would suggest purchasing a factory service manual, or at least a Chilton/Haynes manual. Feel free to post up to ask questions before working under your CJ.Got down to the one bolt on either end of the plate and the body mount. Took one of the remaining plate bolts off and the tranny/case sagged down. Scared theout of me. Glad I left on the loosened body mount nut in the center of the plate.
110%Do NOT use Dex or any ATF in that T5 tranny-AMC learn'd that along time ago. ATF Killed a bunch of'em. This was AFTER Borg/Warner said, 'don't do it'.
Valvoline oil has an excellent syn tranny oil for the T4/T5.
This is what I have used since it came out.
Valvoline SYNCHROMESH - Manual Transmission Fluid | O'Reilly Auto Parts
110%
Make sure the fan didn't contact the radiator.
