motorcraft 2150
motorcraft 2150
rr41mag
Full Time Jeeper
Panama city florida
04 dodge truck, 1966 chevy truck, 2012 rav4
And finally a 1981 jeep cj7 258 hardtop
What vehicles did these carbs come on? Just in case im out junkyard hunting and decide to look for one
Late 70s, early-mid 80s ford trucks, vans, cars anything from a 300 i6 to 351 v8s. 2100s go back into the 60s but are basically the same carb. The 2150 is the revised version with some emissions junk added to it, but still a good carb. You can also find mc2100s on 70s jeeps with a v8. If you have a AMC 258 i6 / 4.2l you'll need the one stamped 1.08 on it.
Droooiiddd 2
V8 CJs came with them.
V8 equipped full size Jeeps had them but usually on a 360 and that's the "bigger" 2150 that isn't as desirable as the one on the AMC 304 .
If you manage to find an old AMC car with a AMC 304 , it would have one.
I'm not sure which Ferd cars came with them. I know the 2150 was used on a lot of 302 equipped cars over the years.
Late 70s, early-mid 80s ford trucks, vans, cars anything from a 300 i6 to 351 v8s. 2100s go back into the 60s but are basically the same carb. The 2150 is the revised version with some emissions junk added to it, but still a good carb. You can also find mc2100s on 70s jeeps with a v8. If you have a 258 you'll need the one stamped 1.08 on it.
Droooiiddd 2
The 2150 also has the altitude compensator built in, which really does work well.
do you need one, I have one I'm not gonna use and will be some what in your area this weekend.
