Build Thread My Cj-8 build thread
:laugh: That doesnt happen around here. If you look at the pic with my emmision stuff removed right below the carb adapter plate you'll see where mine was plugged due to not having power brakes.
Heaven forbid I should hijack a thread.:D
that should work. :D
I think you need a bit more return spring on the throttle, what you have won't support your weight.
Ok. Im not responsible for what the previous owner of a parts vehicle did though. :D
Wow, go wide open throttle and then the springs interlace into each other and then you have a carb that won't close. That would be scary.
I never thought of that, that would be bad.
That is a great point. I'll be sure to post a pic of the bracket Im making for my return spring. You shouldnt need multiple return springs in the first place.
yea sumit and jegs both sell them. It's a safty thing incase one breaks, I ran them when I had a carb.
That carb looks like it belongs there. nice little upgrade. I run the double spring set up from Summit also. they are nice light pull but work well and its nice to have the insurance if one breaks.
I had the spring fall off the carb on my old chevy that I had. The pedal fell to the floor, and the truck stayed at idle. Enough to scare the :dung: outta me though.
Thanx for setting me straight guys. Dual carb return spring from Summit it will be then
The clutch on the Scrambler has been less than desirable for a little while. I wasnt gonna mess with it since Im going with an auto but I figured Id adjust it out till then. I'll show you the scary pics of what I found as soon as the new parts come in.
$90.00
  45.0%
