Need help to ID my transmision
PRS
Cabo San Lucas Mexico
1981 CJ5
Hello all, noobe here, I have a 1981 cJ5 4 speed and I need to know how to identify which tranny I have so I can replace the shifter these are the only numbers I can find on it, please advise thanks in advance
just take pictures of the Transmission from as many angles as you can. is it a 3 or 4 or a 5 speed?
If stock could be a SR4 or T-176 . Is the stick curved or straight?
It would be a good thing if you were to get down under the Jeep and take pictures of the machine that is at the bottom end of that stick.
stick is straight and it is a 4 speed thank you
Thats a T-176 /7 by the shifter. :chug:
T-176 .jpg" data-src="/community/proxy.php?image=http%3A%2F%2Fwww.jeep-cj.com%2Fgallery%2Ffiles%2F1%2F6%2F7%2F1%2Ft176.jpg&hash=5ebd2c48ceea649dfbb876a0f17d6e90" data-lb-sidebar-href="" data-lb-caption-extra-html="" data-single-image="1"> t176.jpg
Can't read the numbers in your photo. This *should* be correct;
5359389= T-177
5359390= T-176
I bought a T177 that was advertised as a T-176 .
Why do you need to change the shifter?
I am with Petescj on this just seeing the stick & tag area T-176 .
176-177 same thing until you buy parts. Since can`t see numbers, need them listed.
Is shifter or case broke? Or retainer-washer-spring? It will be cheaper to repair then replace.
