Not good with Electric...
steveno
Hi, wanted to throw this out there to see if any possible diagnosis....
I have an 84 CJ7 , 6 cycl., TBI from chevy 4.3l, Spark control, HEI coil.
Ok, everything was running fine, went to start one morining after a rain. And just got a click, so I took the cherokee to work.
Got back to the CJ and tried to start it, same thing. Sometimes the aftermarket alarm wich has a kill feature acts up. (which I will be removing) So I checked wires and fuses on that and noticed a horn wire was broken from one of the connectors to a horn.( I have four horns aligned in a row) Anyway connected that and messed with the alarm some more got the jeep to crank but didn't turn over. I also noticed I didn't hear the fuel pump prime as key passed acc to ignition to start. After trying a few time with a friend listening for fuel pump we noticed some smoke in engine compartment. The isulation burned off a wire, it goes from a ground block on the firewall the firewall at the blower. Two wires going to blower a brown one that clips in and this one right next to it that appears to go to the blower. the wire appeared to be intact so I taped it. I also noticed a ground wire from the battery, the side post not top post of battery. The wire went to a ground block with a few other wires. now the ground that burned went to another block. Anyway the battery ground was touching the mounting bolt of the block a friend said that could be the problem. So I remounted so it wouldn't touch. During this the starting selonoid starting making noise, loud clicking. and engine wouldn't crank. I replaced that and it cranked again. I noticed no fuel in the TBI and check for spark, nothing. Thinking maybe fried ECM and or control Spark Module. Getting ready to mess with this one more time before I take to mechanic or make worse. Oh I replaced fuel pump, still no prime from that. thinking the ecm isn't sending signals to anything. Any ideas?
Thanks.
Thanks.
