Oil pan bolt problem
raser13
festus,MO
1977 CJ-5 '83 amc 258 straight six, motorcraft 2100 carb ,inline fuel pump, 1000 cca battery ,T-175 tranny,
you will have to find someone with a SBC to answer this one.:chug:
Why would i need some one with a small block chevy? I have an AMC 258 i6 / 4.2l straight six.:chug:
Ah i see the confusion. I just ripped out the chevy 350 about 3 months ago. I put a bone stock amc 258 straight six with a 2100 carb. I haven't updated the vehicle stats since then.
I just don't want to have to tow this thing 40 miles to the garage were my picker and heavy tools are. Just to lift the motor to take out one bolt! There has to be a trick I'm just overlooking. And I'm hoping one of you can help me with what it is. Thanks
Why would i need some one with a small block chevy? I have an amc 258 straight six.:chug:
Cause your profile says Chevy 305. ;)
Support the engine and remove the motor mount.
I used my engine hoist to lift the engine slightly, that allowed me access to the bolt with no problem. I did not have to unbolt the motor mount. There was enough give in the rubber mount to allow this.
Btw thanks for the suggetions. I'll have to see if i can get my floor jack and a block of 4X4 to work at lifting the motor. If not i gotta pay the tow guy a hefty fee.
I haven't done it myself but I've read quite a few times in my past research about having to do as the others suggest, removing the motor mount after jacking up that side of the engine.
Thinking it over, I now remember removing the motor mount, not just lifting the engine a little bit with the mount still attached. It's been almost 25 years since I removed a AMC 258 i6 / 4.2l oil pan while still in the vehicle. Senior moment I guess! :o
next time use a crows foot, save the time.. snap on, mac tools, even craftsman tools. but a shaved down universal is the real ticket.
yessir
Engine Oil
