oil pan
oil pan
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
I cleanded the oil pan and motor block off, got rid of the old gasket. The manual says to loosen all the crank end caps when working on the main rear seal. Does this sound right and is there a right and wrong in the pattern when tighting the caps back up. This is a AMC 304 AMC any idea on the torque. I would like to compare to my manual. thanks
Good response Posi..
When I read your post driver007 I was going to say "yes, loosen up all the bearings" but then I saw Posi said that plus gave through step by step with pictures.
Great answer Posi.
A big thanks I removed the end cap placed the inside seal in the end cap. when I put I put the one on the outside of the end cap it was short. I then seen that they have it that way for the pan gasket to mate into it. when you look at the gasket on the end cap it looks short. But fits together I will install tommorow. Does it matter when you torqe if you start in the middle or start from the end. I understand stepping it I have done that before. once again thanks
I loosen the cap bolts from the rear of the engine forward and reversed the order on installation, stepping as mentioned.
My understanding is you tighten the bearing caps in the middle first. Work your way outward.
I will have to print that one off. No way in heck I would remember thanks
FSM doesn’t mention an order just to tighten evenly, but I would use Dave’s post as a guide especially if you’re loosening all the cap bolts. I recall loosening three sets and it was enough to relieve the pressure to remove the seal.
What is the proper word to use when you bitch up a rear top part of the main seal. The old one came out easy with a drift. I soaped and oiled as per instructions. Started out fine then it started to peel the last inch of the top part of the seal. I may loosen off some the end cap bolts to help the install. Next step, order to sets of seals. Live and learn.
You'll have to get a new seal.
Next time loosen all the bearing caps.
I believe you used the proper word!!!
At least it wasnt something irrepairable...
Try a short cut after being told how shame on me, for sure I will loosen.
Thanks for the tip of loosening all he bearing caps to ease removal of the seal. No mention of this in the AMC Jeep TSM, all they mention is removal of the main bearing cap!
Try that first but I always find the seal won't budge. Then you can try loosening the other bearing caps. That's what I always end up having to do.
remember you don't have to remove any caps but the main rear. Just loosen the others.
:o I hear ya, Dave. Maybe since it's only been 5 years with minimal milage it'll go easier on mine, nonetheless it's a great tip !
Engine Oil
