Old man emu YJ spring conversion
Lockers and the OME YJ spring conversion rank at the top of the list for best improvements, for me anyways.
I'm keeping my body lift (only 1") make clean up easy after wheeling
I would to but mine is about 3 inches. Not good. I may go with a 1 inch but I think that will keep me from getting in the garage. I already have to take the top down to make it in how it's configured now
Ordered my kit last week. Just waiting for it to arrive
So what kit did you order ? What brand of spring and lift size ?
Old man emu. 2.5" got it from Rocky road outfitters
Was there a medium or HD load springs? Or just 1 set load with 2 1/2 inch lift. I’ve had my Warn 2 1/2 inch springs for 30 years now, actually like that height but they are stiff. Probably why they are not drooping at all.
Nice to hear. Looking forward to seeing your install.
Your definitely going to notice the improvement in flex and ride. :)
They had both medium and heavy duty. I went medium
I'm waiting to see how much lift I end up with. They say it's around 3-3.5" once you factor in the shackles and new mounting point
Thanks that helps me a bit. I definitely don't want any body lift with mine then. I'm betting with how sad my current springs are I'll be more toward the 3.5. What did they cost total if you don't mind?
1,677.00 shipped. That's the complete kit (I probably won't use all of it) that comes with the springs, mounts, shocks, extended brake lines, Transfer Case drop, bushings, etc. I'll post detailed pics before I begin.
I will also do floor to frame measurements front and rear. This way I know the total lift I end up with. My rear is riding high and my front is saggy. So hopefully I have an even ride height. I just hope it doesn't lift it to much or I may try to see what I can do to lower it a bit.
He did tell me the only difference between medium and heavy is one spring and they sell that as an on for 40 bucks if I need heavys for the rear. So it wouldn't be a terrible change once I install and use it for a bit.
I'm glad you didn't get a whole lot of lift. I don't really want it to be higher than it already is. A little is fine (even with the rear would be best) as far as ride quality I'm sure anything is an improvement over my current setup.
Got my tracking number it will arrive Thursday
You should notice a pleasent difference in ride quality afterwards ;)
I would hope so
I bought Rubicon express 1.5 s.o.a leafs for yj remounted front2.5" wide eye on frame very nice setup but needs antiwrap bar even with heavy leaf option
I’m late part to the party.
I ordered YJ oldman emu 2 1/2 inch lift did the shackle reverse and Fox 2.0 shocks.
Holy smokes what a difference
OME also makes extra leaf spring, which I added front and rear.
The droop is phenomenal. Sway bars front and rear for highway.
The ride is wonderful.
Keep in mind my early CJ had inch and three-quarter wide spring.
Good luck
$150.00
  75.0%
