Old man emu YJ spring conversion
I’m late part to the party.
I ordered YJ oldman emu 2 1/2 inch lift did the shackle reverse and Fox 2.0 shocks.
Holy smokes what a difference
OME also makes extra leaf spring, which I added front and rear.
The droop is phenomenal. Sway bars front and rear for highway.
The ride is wonderful.
Keep in mind my early CJ had inch and three-quarter wide spring.
Good luck
Over the years I haven’t heard a lot of good things about the shackle reverse. Was there a reason you did that ?
I wanted more stability on the highway and less wander. The front will dive on hard braking but with the Fox shock I adjusted the damping to compensate for that.
Love the ride now
Hopefully after Christmas I'll be doing my install
On your engine placement. Not sure what engine you have or mounts but I have seen where R and L mounts were swapped moving the engine forwards. I'm pretty sure you would catch that, but I thought I would throw that out there.
Appreciate it. It's the mounts that have been in there since I got it almost 20 years ago. They are correct (left and right) I'm thinking the frame side mounts might be 4 banger. (Jeep always had a AMC 258 i6 / 4.2l but not sure if it left the factory that way) I have a customer who has a second set of 4.2 frame mounts (yes one is different than what I have) I'm going to try that first and see if it makes a difference. If not I'll drill new holes and move it where I want
Appreciate it. It's the mounts that have been in there since I got it almost 20 years ago. They are correct (left and right) I'm thinking the frame side mounts might be 4 banger. (Jeep always had a 4.2 but not sure if it left the factory that way) I have a customer who has a second set of 4.2 frame mounts (yes one is different than what I have) I'm going to try that first and see if it makes a difference. If not I'll drill new holes and move it where I want
LMAO @ ME! 🤣
I thought you were talking about the engine in the Stang, not the CJ. :chug:
My Limited experience with OME stuff, from back in the day, is that it's very good. You should be happy with it.
If/when you get around to installing the springs, you'll likely have to do a bit of grinding on the front end, at the passenger side spring pad, on the inboard side. That little extra width in the spring means some surgical angle-grinding at the diff casting web there. No big deal, but just a bit annoying if you weren't expecting it.
I went with new front YJ Shackle Hangers from Fishbone Offroad. Compared to the originals, they bolted up in a spot where the bushing bore is a bit further forward, maybe 3/4". Guess this accounts for the slightly longer springs.
Nice. So looking forward to this. Here's to everything going smoothly. 🍻
Nice. So looking forward to this. Here's to everything going smoothly. [emoji482]
So far so good. Very minimal issues considering what I had to do
Not all Jeeps had that bracket. Even if mine did originally it's been long gone.
As far as the ground straps I have mine grounded else where and in a few different places.
Kinda what I was thinking. Just curious.
Looking good.:tu:
$90.00
  45.0%
