Omix-Ada Exhaust Manifold for AMC V8's...anyone?
65reissue
Alpena, AR
77 Jeep CJ5 - Renegade - 304 w/3 spd - pretty stock at the moment.
Anyone bought any of the Omix-Ada Exhaust Manifolds for CJ with AMC V8's yet? I am having a 360 put in and haven't found much good said about headers...was advised to go the manifold route. I am not having much luck in tracking any options down except these from Omix-Ada...part number 17622-10 and 17622.09. Just wanted to see if anyone has had any experience with these manifolds or not? As always...thanks!
I haven't seem them. BUT, have'n seen many products with that brand name. I
would be looking in the junk yards first-
Thanks ... I have been looking around and actually having a pretty tough time finding anything. Haven't posted on Craigslist yet...but would like to get into an original set. thanks again.
as said omix=junk
j&w (link posted above) will have them but when i bought mine they wanted $AMC 150 each. if you aren't in a hurry then i would be searching craigslist and posting a wanted ad here.
Most any AMC V8 manifold will work on the passenger side. Plenty of those are available especially for Wagoneers. The drivers side drivers side is a different situation. You need a rear dump manifold to clear the clutch/steering linkage.
I've often wondered if a custom exhaust shop would be able to work around the problem areas on the left side.
If you are replacing the AMC 304 why not use those? they are the same, I think.
$210.00
  100.0%
